I've created my pipe network, renamed the pipes but when I try to export to file the following error message appears :
Unhandled exception has occurred in a component in your application. If you click continue, the application will ignore this error and attempt to continue.
Conversion from string "006 (1)" to type 'integer' is not valid.
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidCastException: Conversion from string "006 (1)" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)
--- End of inner exception stack trace ---
at MDLink.CmdExportFile.ExportFile()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2110.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 20.1.0.0
Win32 Version: 20.1.49.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcdbMgd.DLL
adui20
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/adui20.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AdUiPalettes.DLL
WindowsBase
Win32 Version: 4.7.2106.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Configuration
Win32 Version: 4.6.1586.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 4.7.2102.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
Win32 Version: 6.3.0.14
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AdApplicationFrame.DLL
AdWindows
Assembly Version: 6.3.0.14
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AdWindows.DLL
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcWindows.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AeccUiWindows
Assembly Version: 10.5.1132.0
Win32 Version: 10.5.1132.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/AeccUiWindows.dll
AeccUiWindows.resources
Assembly Version: 10.5.604.0
Win32 Version: 10.5.604.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/en-US/AeccUiWindows.resources.DLL
System.Windows.Forms
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AmbercoreEngine
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AmbercoreEngine.DLL
AmberCore.IsdCodecAPI.Core
Assembly Version: 5.0.0.343
Win32 Version: 5.0.0.343
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AmberCore.IsdCodecAPI.Core.DLL
AecMgdReverse
Assembly Version: 7.8.44.0
Win32 Version: 7.8.44.0
CodeBase: file:///c:/program%20files/autodesk/autocad%202016/aca/aecmgdreverse.dll
AecRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/ACA/AecRibbon.dll
AecGuiInterop
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/ACA/AecGuiInterop.DLL
AcMapResourceManagement
Assembly Version: 19.0.20.16
Win32 Version: 19.0.020.16
CodeBase: file:///c:/program%20files/autodesk/autocad%202016/map/AcMapResourceManagement.dll
AcMapLoader
CodeBase: file:///c:/program%20files/autodesk/autocad%202016/map/acmaploader.arx
ConvertText
CodeBase: file:///C:/program%20files/autodesk/autocad%202016/map/ConvertText.dll
MapPublishImp
CodeBase: file:///C:/program%20files/autodesk/autocad%202016/map/MapPublishImp.DLL
OSGeo.MapGuide.PlatformBase
Assembly Version: 2.4.0.6234
Win32 Version: 2.4.0.6234
CodeBase: file:///C:/program%20files/autodesk/autocad%202016/map/OSGeo.MapGuide.PlatformBase.DLL
OSGeo.MapGuide.Foundation
CodeBase: file:///C:/program%20files/autodesk/autocad%202016/map/OSGeo.MapGuide.Foundation.DLL
Autodesk.Map.Platform
CodeBase: file:///C:/program%20files/autodesk/autocad%202016/map/Autodesk.Map.Platform.DLL
Autodesk.MapGuide.Studio.Site
CodeBase: file:///C:/program%20files/autodesk/autocad%202016/map/Autodesk.MapGuide.Studio.Site.DLL
AcMapFeatureEntityTooltipsManager
CodeBase: file:///C:/program%20files/autodesk/autocad%202016/map/AcMapFeatureEntityTooltipsManager.dll
ResourceManagerRdfImp
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Map/ResourceManagerRdfImp.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
PresentationFramework-SystemData
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
AcC3DReports
Assembly Version: 2016.1.0.0
Win32 Version: 2016.1.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Transportation%20Extension/AcC3DReports.dll
Autodesk.AECC.Interop.UiLand
Assembly Version: 10.5.0.0
Win32 Version: 10,5,604,0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Autodesk.AECC.Interop.UiLand.dll
Autodesk.AEC.Interop.UIBase
Assembly Version: 7.8.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/ACA/Autodesk.AEC.Interop.UIBase.dll
Autodesk.AutoCAD.Interop
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Autodesk.AutoCAD.Interop.DLL
Autodesk.AutoCAD.Interop.Common
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Autodesk.AutoCAD.Interop.Common.DLL
Autodesk.AECC.Interop.UiRoadway
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Autodesk.AECC.Interop.UiRoadway.dll
AcExtraTransparents
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Transportation%20Extension/AcExtraTransparents.dll
AcLineDirectionDistance
Assembly Version: 2016.0.1.0
Win32 Version: 2016.0.1.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Transportation%20Extension/AcLineDirectionDistance.dll
EmbeddedSQLiteLoader
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/EmbeddedSQLiteLoader.dll
AcMapInfoCenter
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Map/AcMapInfoCenter.dll
AcPipeNetworkRenaming
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Transportation%20Extension/AcPipeNetworkRenaming.dll
AeccDOT01
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Transportation%20Extension/AeccDOT01.dll
System.Design
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
AeccPartPublishingWizard
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/AeccPartPublishingWizard.dll
AeccSurveyX
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Transportation%20Extension/AeccSurveyX.dll
AeccSurveyX.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Transportation%20Extension/en-US/AeccSurveyX.resources.DLL
AeccTraverseEditor
Assembly Version: 10.5.112.0
Win32 Version: 10.5.112.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Civil%203D%20Productivity%20Pack%203/AeccTraverseEditor.dll
AeccDbMgd
Win32 Version: 10,5,1132,0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/AeccDbMgd.dll
AeccUiCogoMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Civil%203D%20Productivity%20Pack%203/AeccUiCogoMgd.dll
AeccCogoHistoryMgd
Win32 Version: 10,5,112,0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Civil%203D%20Productivity%20Pack%203/AeccCogoHistoryMgd.DLL
FeaturedAppsPlugin
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2016/Win64/FeaturedAppsPlugin.dll
GenioC3D
Assembly Version: 10.5.16.0
Win32 Version: 10.5.16.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/GenioC3D.dll
MXC3D
Assembly Version: 2016.0.0.0
Win32 Version: 2016.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/MXC3D.dll
C3DVSP3D
Assembly Version: 3.3.0.0
Win32 Version: 2016.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/C3DVSP3D.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcWindows.dll
AeccUiMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/AeccUiMgd.DLL
AeccPressurePipesMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/AeccPressurePipesMgd.DLL
AcMapRibbonWrapper
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Map/AcMapRibbonWrapper.dll
AeccContextTabRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/AeccContextTabRules.dll
AcMapRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Map/AcMapRibbon.dll
AeccWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/AeccWindows.DLL
AecBaseMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AecBaseMgd.DLL
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Microsoft.Expression.Interactions.DLL
ManagedMC3
Assembly Version: 8.5.0.0
Win32 Version: 8.5.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/ManagedMC3.DLL
AcLivePreviewContext
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/en-US/AcLayer.resources.DLL
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcMrUI.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/en-US/AcMrUi.resources.DLL
FeaturedAppsPlugin.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2016/Win64/en-US/FeaturedAppsPlugin.resources.DLL
AcCommandToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/en-US/AcCommandToolTips.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Autodesk.IDM.AutoCADEmbedded
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Map/bin/Autodesk.IDM.AutoCADEmbedded.dll
Autodesk.IDM.Embedded
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/Map/bin/Autodesk.IDM.Embedded.DLL
AeccMgdReverse
CodeBase: file:///c:/program%20files/autodesk/autocad%202016/c3d/AeccMgdReverse.dll
AeccDotNetUtils
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AeccDotNetUtils.DLL
MDLink
Assembly Version: 10.5.9.0
Win32 Version: 10.5.9.0
CodeBase: file:///C:/ProgramData/Autodesk/C3D%202016/enu/Data/Reports/WinDes/MDLink.dll
Assembly Version: 10.0.0.0
Win32 Version: 14.6.1586.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Autodesk.AECC.Interop.Pipe
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Autodesk.AECC.Interop.Pipe.dll
Autodesk.AECC.Interop.Land
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/C3D/Autodesk.AECC.Interop.Land.DLL
Autodesk.AEC.Interop.Base
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/ACA/Autodesk.AEC.Interop.Base.dll
CustomMarshalers
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Any ideas on what is causing this error and how it can be fixed?
Solved by MikeEvansUK. Go to Solution.
Please check the numbering again. Windes expects values of 1.000 to 1.001 etc. It looks like somewhere there may be a duplicate pipe named #.006 (1).
Its hard to diagnose these errors from the windes tool but generally speaking they are caused by the following;
incorrect numbers not pertaining to the 1.xxx numbering
numbers (as above) containing text (1) mostly due to user modifications (splitting pipes or inserting manholes, civil3d will name the new pipe as #.### (1))
Numbers not being of a true increment, Leaping from branch 1 to 3 without having 2 in the model.
I don't think I have found anything else so far.
@MikeEvansUK is correct, this has occurred due to incorrect pipe numbering. You need to number from the start of the longest run to the outfall as 1.000 >, then the next adjoining pipe run as 2.000 > etc
Thanks Mike & MMCGOVERN - I've managed to successfully export the pipe network as an .SWS file. However when I try to import the SWS file into microdrainage the following warning message pops up - the specified pipe size file (Standard.PIP) cannot b elocated. would you like to specify a new file?
Any idea what causes this message and how It can be fixed? Is it related to the pipe part I have used in civils 3D?
many thanks
Scott
No this relates to the standard files within microdrainage that contains the pipe sizes and manhole sizes that your company uses. You can create your own from within microdrainage.
