Is there a way in AutoCAD to calculate the average width between two irregular lines, such as the average width between stream banks?
In the past I've been able to get a reasonable approximation using this method. Start by calculating the average length of the two lines. Add two temporary lines at the ends to get a closed area. That area divided by the average length should give an average width.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
