Material on Corridor
I have finish preapring and i want to have materail on the corridor for visulaization purposes, my question here is how can we have the best visualization on corridor in C3d.
thanks
nikoue
Very long discussion.
You must first have to understand code set styles,
You must assign materials in the top links of you corridor, This controlled by code set styles.
Make a search for civil 3d code set styles in youtube and you will find videos and webinars that explain very well the code set styles.
And if you want more there is the civil view witch connect civil 3d with 3ds max design. But you must have also the 3ds max design and have some basic knowlege on this.
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
neilyj666
I'd do visualizations in Infraworks (3ds Max is arguably better but a steeper learning curve).
If you try visualizing a corridor in C3D with realistic textures, the performance degrades to the point of being unusable in my experience.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
nikoue
"If you try visualizing a corridor in C3D with realistic textures, the performance degrades to the point of being unusable in my experience"
No i don't agree with you.
Its all about the correct code set style. Make a code set style in witch you will set all points to a no display style and all shapes to a no display style.
Assign materials to the top links, and last create an Autocad view style by copying the realistic style and in the edges settings put show: none.
Also in autocad options, in the selection tab, in the preview options turn of the two options " When a command is active" and "when no command is active"
With these settings and with your pc specifications you can orbit smothly any corridor.
If you give me a model i can make it for you.
And for the friend from the first post
neilyj666
"...in my experience..." doesn't extend to the methods you are suggesting; I'll try them the next time I do a corridor...:)
