- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have 3 different computers all running Civil 3d. Two of them are on 2020 and the other one is on 2019. We do a lot of drone work for surveying and have recently been trying to convert the tif file output from pix4d to an ecw file format that can be inserted into autocad. Some of our tif files are too large for autocad. We use global mapper to convert the file from tif to ecw. On two of the 3 computers, when we use the mapiinsert command, it references the eww world file and sets the units to inches and brings the image into the correct location. On the other computer (one of the 2020 ones), it does not reference the world file for the correlation type (only the image file), and by default it chooses feet which does not insert into the correct location. Everything is way off to the right of where it should be. We just figured out this morning that the units didn't match up and on this computer that acts differently, if we set the units to inches, it will insert to the correct georeferenced location. I need to figure out why the one computer on 2020 does not reference the world file and how we can fix that. It seems to be the issue, but maybe I am way off base. This is a clean install of 2020 and no settings have been set by the user. The template we use is set to unitless. I appreciate any help! Thank you!
