i cant use mapexport command. I had try to repair and uninstal but it still not work. How can i fix it?
Solved by namlt33. Go to Solution.
I have found where the error is. When install custom coordinate systems i accidently paste the .csd file into coordinate systems folder. After wipe out the folder contents everything work normally
