Hi all,
I have several drawings to transform from DHDN to ETRS89. I would like to check the accuracy of the transformation by compare the lenght of all (poly)lines in the DHDN drawing and in the ETRS drawing. I know there`s the MAPDIST command to meassure the lenght, but I have to do them with click on two points.
But I have a lot of lines in the drawing. So is there an other command who meassure the lenght of all lines in the drawing by themself (without user intervention) and store all lines with lenghts in a seperate file or table?
Thank you,
Jeannine
DataExtraction hould give you the results you are looking for all polylines in the drawing.
run Dataextraction.
Select Polylines
Then Geometry then length. Output is to a .csv .xls .mtb or .txt
Hope that helps!
I tried dataextraction.
That works, but I also nedd the coordinates from each polyline. In the output are fields with start x/y and end x/y. But there empty in the csv file, because in properties of the polyline are just the coordinates from the vertex point.
How can I add the vertex in the output fields?
Jeannine
Rick Jackson
Survey CAD Technician VI
Yes, that would be simple. But that`s a work for my bachelor theses and my prof would like to have the lenght of all lines 😞
If it`s not possible to add a field with the vertex coordinates of the lines maybe I will meassure a few lines in each drawing...
Well how about creating survey points at all the vertices (you could convert each to a polyline) export each set of points which would then give a the coordinate value from which to come each drawing with in a spreadsheet.
Rick Jackson
Can I do this automatically or have I do this manuell at each line?
Because that are thousands of polylines in each drawing 😞
