Mapcsassign asking code?
Message 1 of 11
Hi
whenever i use Mapcassign command it is asking some code in my civil3D.
I have attached screenshot.
Please help me with this issue.
Thanks & Regards
Ravishankar H S
Replies (10)
Message 2 of 11
Pointdump
Ravi,
Set _FILEDIA to "1" or enter a tilde (~) in response to the Command prompt.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 11
Hi @Pointdump
No it's not the problem with Filedia, Filedia is set to 1.
All commands other than MAPCSASSIGN is working fine.
Please check the attached screenshot.
when i type MAPCSASSIGN command it is taking command as MAPCSASSIGN code, the coordinate system window is not appearing.
Best Regards
Ravishankar H S
Message 4 of 11
Pointdump
Ravi,
OK, so you have FILEDIA=1. Did you try typing a tilde (~)?
The only other thing that would prevent the dialogue box from opening is if you had a active Script, a LISP loaded, or ObjectARX(whatever that is).
I can't think of anything else. Maybe someone will suggest other things to try.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
Pointdump
Ravi,
One more thing to try. Check <<<Support File Search Path>>> in _OPTIONS.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 11
Jeew-m
Dear Friend,
Have you tried _MAPCSASSIGN command.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 7 of 11
WarrenGeissler
The setting you are looking for is CMDDIA = 1
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 8 of 11
Pointdump
Ravi,
Warren might be right about -CMDDIA. I didn't suggest it because in the Help it says, "Suppresses the display of the In-Place Text Editor and certain dialog boxes." And NONE of those "certain dialog boxes", which are listed <<<Here>>> include _MAPCSASSIGN.
So as a test, I changed both -CMDDIA and -FILEDIA, one at a time, to 0. Both will give you the same Command Line request for a Code. And the Tilde (~) does NOT work to give you the dialog box.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 11
Hi @WarrenGeissler
Yes, cmddia is set to 1 and mapcassing command is working fine.
Thanks a lot
Message 10 of 11
mubeenbinsafdar
Observer
Observer
CMDDIA = 1
FILEDIA = 1
TILEMODE = 1
and mapcsassign will start working.
Message 11 of 11
jeff_bone_horrocks
Observer
Observer
Thanks, the FILEDIA=1 is what worked for me!!
