Was running the MAPCHECK command and right when I was about to export the data, the mapcheck dialog box disappeared. I type in MAPCHECK through the command line and nothing comes up, I also clicked the MAPCHECK command from under the survey tab ribbons but nothing appears.
Solved by tcorey. Go to Solution.
Are you sure you don't have Auto-hide enabled for that window and that it is showing up as just the sidebar, not the entire dialog?
