Manually Adding a Station
skintsubby
Advisor Advisor
skintsubby
I've been trying for a while now and I'm hoping someone can show me where I'm going wrong..
All I want is to manually add a station in between to other stations.... ie I can produce this-->
However I would prefer to produce this -->
Which has an additional station added as required from time to time.
Thanks for reading.
andrewpuller3811
You can manually add extra stations such as you want with station equations in the alignment properties.
To get the stations to be labeled, you need to have a station equation label in the alignment label set.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
mathewkol
What about a simple station-offset label?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
skintsubby
Thanks Andrew.... and Matt.
I just needed a pointer in the correct direction. I've now got it working how I want it
Mark
