manhole size and constructubility
Hidden_Brain
Advisor Advisor
Message 1 of 8
Hidden_Brain
I have a drainage system laid out which has quite a few manholes with multiple pipes coming in at various angles. I am looking to get some suggestions/recommendations on how to use the available tools to make determination how big a manhole needs to be based on the pipes coming in.
Typically, we try to have at least 6 inches of concrete in the inside wall of the manhole between pipe OD+2" coring. I have approximately 50 manholes like this. Is there any easy way to figure out based on incoming pipe angles, pipe dia and material (thickness) that I can make a determination on the manhole size?
I am interested to know how everyone is doing this? I appreciate any help on this.
Replies (7)
Message 2 of 8
Jay_B
This free MH size calculator might help.
http://www.cretexconcreteproducts.com/node/204
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 8
Joe-Bouza
Same line as Jay, Google and talk to your local precaster
Joe Bouza
Message 4 of 8
Joe-Bouza
You definitely want to leave some meat on the bone
Joe Bouza
Message 5 of 8
Hidden_Brain
Thanks for the link, I have something similar from a precaster. I am trying to automate/semi-automate getting the angles between the connected pipes out for the entire drainage network so that I can feed those in to a tool like this. Any suggestions?
Message 6 of 8
Matt.Anderson
Hidden_Brain -
I think this should cover what you are looking for.  https://apps.autodesk.com/en/Detail/Index?id=3913582902813411430&appLang=en&os=Win32_64
Its a well designed tool that I used very early on for a number of projects.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 7 of 8
rpatrickVEJ49
Community Visitor
Community Visitor
I know this is an old thread, but I had to check.
I used to have that cretex MH size calculator on my desktop, until our company servers got hacked and I lost it. The link you posted now goes nowhere, I think Cretex may have sold this division of their company? Anyways, do you know of anywhere else I could get this MH Calculator, or something similar? I've been searching online today with no luck.
Message 8 of 8
MattAndersonPE
The
Matt Anderson
Product Manager
