I'm using Civil 3D 2016, and I have an active pipe network file which I created a network of pipes and structures. I XREF into the DWG a surface file, which contains the proposed ground surface.
I want to make the object surface active in the same file, not as an XREF. In microstation, I could simply copy and paste and it would become active, then I would detach the ref. How do I do that in Civil 3D?
