Macro file not found at original path specified in subassembly. Updated macro fi
Bkilen
Bkilen
I have recently uninstalled and reinstalled 3d civil 2015 and I keep getting this error when using the subassembly
Macro file not found at original path specified in subassembly. Updated macro file...  What can be done about this..
Brad
Bkilen
Attached is a Photo of the error
Jeew-m
Dear Friend,
Usually this comes when you are opening a file with a separate version of Civil 3D other then the file is created. For example you create the drawing with 2014 version and then you open the file in 2015 version. For these versions the macro file which related to corridor is at separate locations. So Civil 3D gives you an information it gets the macro file from a different location. However they are same and no harm to your dwg.
It is just information. No need to worry.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
hello
i have same problam here . but its not about diffrnt bitween versions !
i am just opening my civil2016 and when i wanna put a simple subsassmley from toolpalettes i recive this .
