Solved by nzeeben. Go to Solution.
Allen Jessup
CAD Manager - Designer
I am running AutoCAD Civil 3D 2012 and I am getting the same message after a fresh install. Is there a resolution for this error??
Looks like it's still the same in 2019.
"Macro file not found at original path specified in subassembly. Updated macro file location to path defined by AECCCONTENT_DIR environment variable.
However the environmental variable does exist.
Command: (getenv "AECCCONTENT_DIR")
"C:\\ProgramData\\Autodesk\\C3D 2019\\enu\\"
It also exists in the Registry
Just an FYI for the future.
Allen Jessup
I was having the same trouble with my custom subassemblies with a new install of 2019. I found that I could fix the problem by removing them from my tool palette. Opening them with the 2019 subassembly composer and saving them. Then inserting them back into the too palette. Hope this helps out.
Matt Kozak
Autodesk Certified Professional
Hello @Kozak_MJK
Thank you so much for sharing your solution to this problem! Looks like the author's account has been archived, but your solution will benefit other community users who have the same issue!🙂
i ran into the same prompt message. Does getting this message affect the drawing at all?
the message showed up after i export it to autocad 2010 , the technical office is saying the when they import the points to create the surface on another coordinates , far away from the actual alignment . how to solve this problem
