This might be The Last Question I'll have to ask about this project:
I have a model now of a two-lane road with radiuses (radii, I know) as small as 200'. Grades as steep as 7%, and supers as high as 6%.
I wonder what frequency to generate the corridor at to produce the surfaces?
Obviously, I'm going to have to increase the frequency as needed to make the corridor "look right" around the curves and such. And the driveways, being steeper and tighter, will have higher frequencies as needed to describe the geometry to a tighter tolerance.
But I wonder, in general, does machine control "like" a certain range of frequency? Can it be too tight? Or is more frequency always better? Does anyone have any insight drawing from real-world experience?
Solved by Mike.M.Carlson. Go to Solution.
Rick Jackson
Survey CAD Technician VI
Rick Jackson
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
Michael M. Carlson
CADD Manager
