- Mute
- Permalink
- Report
I am experiencing a long delay (10-30 seconds) after I exit any command or grip selection of any type of object.
- This only happens while I am in a "Layout" (Tilemode=0) and working in ModelSpace through a viewport.
- The delays do not happen if I edit objects in PaperSpace or if I am fully in ModelSpace (Tilemode=1)
If I start a new dwg using the same template the affected dwg was started with I do not experience any delays.
I have Audited, -Purge\Regapps, Purged, updated my graphics driver, turned off hadware acceleration, deleted temporary files with o changes.
Currently using C3D 2018.2 for this project, but the behavior even occurs if I open the dwg in C3D2020
Any thoughts?
