Civil 3D Forum
locking structure top elevation
3 REPLIES 3
nostupidquestions
360 Views, 3 Replies
is there a way to lock the structure to elevation? i move a structure and the top elevation changes. the automatic surface adjustment is set to false. should it not stay at the elevation i have typed in? i tweaked an alignment and adjusted a surface and all my tops moved.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
3 REPLIES 3
The surface adjustment setting is an add subtract factor to the rim surface insertion point. What parameter is your label style using? Maybe  not the one you are manually entering?
I'm curious: dont you want the rim to react to the surface elevation?
Joe Bouza
i tried that. after moving the structure it puts the top at 0.00'.
64 GB RAM
C3D 2023.2
bforr
in reply to: nostupidquestions
turn your snaps off or put whatever you are snapping to at the desired elev
Rail Community
