List Alignment curve data
farzad.deldjoui
Message 1 of 9
farzad.deldjoui
Our local DOT requires to list alignment curve data in a non table format, Could you please advise how I can generate a report as shown in attachment. Thank you so much
Replies (8)
Message 2 of 9
rl_jackson
This can be accomplished with a standard label where the drag state arrow is turned off. You just need to set up the style to reflect how you want it to appear in the drawing.
Rick Jackson
Survey CAD Technician VI
Message 3 of 9
jroot
This would be an Alignment Label Style for a Curve.
Below is ours that would get you close to what you need (if you can read it)
Message 4 of 9
farzad.deldjoui
Thank you so much for clarification and your response.
Message 5 of 9
farzad.deldjoui
Thanks Rick.
Message 6 of 9
farzad.deldjoui
I was able to generate the Curve listing, thank you for that, but there is one question I am getting "???" on top line which we intend to assign a tag for the curve, would you mind please advise how to address this issue, thank you so much, please see attached.
Message 7 of 9
rl_jackson
Check your style for the following.
On the layout tab under the Table Tag component verify that Visibility = True.
I believe that if you want to show the data along the line or arc and show both simultaneously you will need to set the Used in just below it to Tag and Label Mode as this will show both the label and tag #.
Rick Jackson
Message 8 of 9
farzad.deldjoui
Visibility is set to True, also I have attached the curve components in the text format which I have for the label
Message 9 of 9
rl_jackson
Yes but to get both you need to have set the Component - Table Tage so that it5 is USED IN Label & Tag Modes,REMOVE and the Tag Component from the Distance & Radius Component. This makes both labels appear.
Rick Jackson
