Lisp to delete overlapping lines with same X & Y and different z
asantosGEG
asantosGEG
Hi everyone,
I have some files with a lot of solids elements and I want to create surfaces from these elements.
Since in C3D, surfaces do not work with solids, I explode the solids and the result will be an overlapping of lines on the plan but with different z's,
I needed a routine that would go through the file and delete the lines with similar x's and y's but different z's. The user would indicate the difference in z's. The difference in z would be indicated by the user.
I'd really appreciate your help, as deleting these lines will take a lot of time.
The image below shows what I want the lisp routine to delete the red lines.
Thank you
hosneyalaa
Hi
Can you attached example drawing
And put your question here
https://forums.autodesk.com/t5/civil-3d-customization/bd-p/190
Joe-Bouza
OOTB: MAPCLEAN
OOTB: OVERKILL
Change the drawing canvas to FRONT and delete with a crossing window
Those should do it handily. Your part is clearly 3d. If you were not aware the Civil3d is a specific type of 3d that does and doesn't really allow for multiple x,y different z.
Not that 3d parts cant be used, they can, but not in a civil3d surface
Joe Bouza
