Civil 3D Forum
Lisp Routine help
9 REPLIES 9
Message 1 of 10
1818 Views, 9 Replies
Lisp Routine help
Hey all,
I have a lisp that used to work just fine before. It gave me quick acreage of an area and was useful for reference.
I am on Civil 3D 2020, and it appears to be broken. It keeps giving me a value of "0". I opened up Visual Lisp to inspect. Lisp follows:
(defun c:AC ()
(SETQ IP (GETPOINT " Pick Internal Point: "))
(COMMAND "-BOUNDARY" ip "")
(SETQ SS (ENTLAST))
(PROGN (COMMAND "AREA" "o" SS))
(SETQ acres (/ (GETVAR "AREA") 43560))
(SETQ Acres (rndby acres 0.001))
(setq ktext (strcat (rtos acres 2 2)" AC" ))
(setq ht 5)
(command "_.text" ip ht "0" ktext)
(princ)
(defun rndby (r b / tmp)
(setq tmp (rem r b))
(cond ((>= tmp (* 0.5 b)) (+ r (- b tmp)))
(T (- r tmp))))
I am trying to find the error in my programming, or a lisp that can do what this one can. Attached is also the Lisp file for those that prefer to mess with it in VLisp.
Edit: Accidently escalated the topic. Eitherway, anyone's input will be helpful.
9 REPLIES 9
Message 2 of 10
Jowennl
Hi @Anonymous ,
Can you please try the following attached Lisp below?
Original source of Lisp: Link
Cheers,
Jowenn
Message 3 of 10
in reply to: Jowennl
Okay so I tried both LSP files. Both are doing the same thing as my LSP. It gives me a value of 0 when I click inside, no decimal spots or anything. I attempted to make a larger square and check to see if precision was the issue, and it was not. They all keep giving me 0.
Message 4 of 10
moogalm
In your code, try changing the tolerance from 0.001 to 0.0001
(SETQ Acres (rndby acres 0.0001))
Message 5 of 10
in reply to: moogalm
The text is still putting a zero as the output.
Message 6 of 10
moogalm
Can you please share test drawing, I would like understand the drawing environment.
Are the coordinates of your PLINE is very far from origin ?, is it pure C3D drawing ?
Message 7 of 10
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. If not, please share the test drawing as mentioned by @moogalm so he can take a look and help you. Thanks!
Lynn Zhang
Message 8 of 10
Good morning,
I have attached one of my sites, and the Lisp. Please let me know if anyone has ideas, thank you all!
Message 9 of 10
user181
It is not because of Civil 3D 2020. It is because the current text style has an assigned height and the routine is written assuming a height of 0 is set for the current text style.
Either set the current text style to one with a height of zero before running the lsp or change the line:
(command "_.text" ip ht "0" ktext)   to   (command "_.text" ip "0" ktext) to use a style with a height assigned.
Or modify the lisp to set a current text style and height.
Message 10 of 10
in reply to: user181
@user181 That was it! Thank you all for your help! this will make things a lot more efficient for those who don't know C3D Catchments!
Rail Community
