LinkVertical output parameter, End Elevation, behaves unexpectedly.
Coffee_Aided_Design
Coffee_Aided_Design
The generic sub-assembly  LinkVertical has an output parameter called End Elevation. The documentation is fairly vague but I understood elevation to mean the global elevation. I tried to use this parameter in another sub-assembly and it appears to be using a relative elevation (probably the assembly marker or insertion point). Is this true? Is there a way I can make this an actual elevation?
Jeew-m
You can use target mapping to set elevation targets to the link vertical.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
