Changing Input Units
Message 1 of 10
I haven't been able to find a direct answer to this question, although I'm sure with such a simple one it exists. My units when I draw anything measure in inches (using Dimensions to determine this). How do I set up a drawing so that any 1 unit is equal to 1 foot?
Thanks!
Replies (9)
Message 2 of 10
rl_jackson
In C3D 1 unit = 1 foot, if your trying to convert architectural units to survey feet you that's a 1/12 ratio
Rick Jackson
Survey CAD Technician VI
Message 3 of 10
I know I can scale everything to be 12 times as large, although I'm not sure if that's what you're suggesting. Is there some setting that will automatically sent the standard drawing unit to be measured in feet?
Sorry if I'm misunderstanding something.
Message 4 of 10
Jeew-m
Are you talking about THIS.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 5 of 10
I don't think so. I've got it in feet for the units, but when I draw a 20 unit line and dimension the line with annotation, it would read as 20 inches or 1' 8".
Message 6 of 10
rl_jackson
In C3D 1 unit = 1 foot. The only units that work in C3D are International Feet, US Survey Feet (circa 2017) and Meters. If you want to draw in inches (or decimals thereof, as a simple solution in C3D) you'll have to scale it x12 to reflect the 1 unit = 1 foot as only generic ACAD has the ability to set 1 unit = 1 inch (default). If you want your dimensions to reflect 1' 8" then that can be done in the dimension style
Rick Jackson
Message 7 of 10
The issue isn't that I want to draw in inches, it's that any line I draw, when I use linear dimension, it gets dimensions in inches when I change the annotation from decimal to anything else. I'm drawing a 128.5 unit line that I want to get annotated as 128' 6", but it comes out as 10' 9".
Message 8 of 10
rl_jackson
OK so now we need to know is this a C3D label (i.e. bearing and distance) which would require an equation, or just a regular dimension that could be done with either a scale factor or alternate units.
Rick Jackson
Message 9 of 10
I think I may have gotten it fixed. I applied scale factor to the standard annotation and it looks like it corrected my issue. Thank you for that!
Message 10 of 10
tcorey
You appear to have settled on a workaround, but the basic error still exists, right?
I often see this problem when an engineer opens a drawing provided by an architect or builder. Even though you have set UNITS to Decimal, the drawing is still stubbornly inch-based.
On the Settings tab of Toolspace, right click the drawing name, very near the top of the dialog.
From the shortcut menu, Edit Drawing Settings. Go to Units and Zone tab. Your Drawing Units might be set to Inches. Set that to Feet.
The safer way to deal with an a outside drawing is to create your blank drawing from a known template, then insert the outside drawing into that, exploded if required. This way, your Dimension styles and Civil 3D Label Styles will already be setup correctly. No additional scaling of styles will be necessary.
Depending on a couple of settings, there is the question of scaling the incoming drawing during INSERT. Read up on InsUnits, InsUnitsDefTarget and InsUnitsDefSource.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
