Civil 3D Forum
Linking View Frames to Sheet Set
2 REPLIES 2
Farouq_Alkhatib_ext
213 Views, 2 Replies
is there a way of linking the View Frames to an already existing sheet set?
Many thanks in advance for any assistance.
Tags (2)
Labels (1)
2 REPLIES 2
  1. Sheet Set Manager (SSM) and view frames are core AutoCAD features.
    You will have access to more potential solution providers in the AutoCAD forum.
  2. You can select Report from the Options Menu [ ⋮ ] and ask that this post be moved.
  3. On to your question:
    I am not an expert with viewports or SSM, But you might find a workaround here:
    Solved: How to add existing views to sheet views tab of sheetset manager?
Good luck!
Christopher Stevens
Paul.GrafPZAZ7
in reply to: ChrisRS
I believe the OP is referring the Civil 3d View Frames that are part of the plan production tools. I too am trying to figure out how to pass along the View Frames and View Frame Groups properties to the sheet set manager when I create my plan & profile view frames.
Paul (c3d 2022)
Rail Community
