- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I try to build a link to elevation subassembly. I`ve just started and I`ve got a problem with P3 point. It is not creating when elevation target is above P1. Please have a look at attached pkt file.
I`ve noticed that P3 is creating when I change Elevation Input parameter to positive value. When the value is negative P2 is created. Anyway it shouldn`t matter because subassembly will be controlled by target elevation (profile or feature line).
When I use subassembly in a corridor, link is not creating in cut scenario.
