Hi @khaledCULN8 ,
Thanks for your post. Could you be more precise on how desire subassembly should work?
As I understand you want to connect two points(one on the left, another on the right side of the assembly) with one link. Do you want to use a subassembly point to anchor that link on one side and target it to the feature line/polyline/alignment/etc on the other side? If so, the best solution - thank you @Joe-Bouza - would be to use Marked Points and LinkToMarkedPoint subassemblies.
However, Marked Points and LinkToMarkedPoints need to have a specific workflow. To automate this little better, I've created a sample subassembly - not sure if I understood your needs correctly.
Please find a PKT file attached. This is a simple example of how to create subassembly that connects two points. In the Screencast below please find workflow explanation:
Custom Subassembly to connect two Points
Be aware to place Marked Points and set their codes before you use LinkPoints custom subassembly.
Although, I would like to know more about your idea. Maybe you can prepare for us a simple sketch to picture the idea better? If we would know better, we can try to find a better solution.
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Technical Support Specialist
Civil Engineering Solutions
