Linework is not aligning with aerial on plot
jacksontdW23TR
Message 1 of 20
jacksontdW23TR
THis is shown before I plot to pdf.THis is shown before I plot to pdf.this is shown after I attempt to plot to pdf.this is shown after I attempt to plot to pdf.
I am having trouble plotting my cad file (there are two viewports in my layout). I am using nearmaps for an aerial background and made sure I have the right coordinate system. However, once I hit plot to pdf, the linework is not aligning with the corridor in the aerial image. You can also see a duplicate viewport. Can you someone please assist me with plotting this correctly?
Replies (19)
Message 2 of 20
pendean
Community Legend
Community Legend
Are you using plain AutoCAD? Or MAP/Civil versions? No 'nearmaps' here.
Looks like your top map location is shifting over to a different area.
Message 3 of 20
Valentin_CAD
@jacksontdW23TR ,
Try:
  1. Optimizing drawing files in AutoCAD with Purge, Audit & Recover
  2. Delete the corrupted or problematic viewport, then create a new viewport.
  3. Or start a new drawing in AutoCAD
  4. Use other options to Georeferenced your image
Other links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 20
Pointdump
Hi Tanesha,
Can you post your drawing and the NearMap image? Zip them together, and if both exceed 71MB, use a DropBox or WeTransfer link.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 5 of 20
jacksontdW23TR
I am using civil 3d. I connected nearmaps to my drawing.
Message 6 of 20
jacksontdW23TR
Thank you, Dave! I have attached the zip file.
Message 7 of 20
Pointdump
Tanesha,
Thanks for posting your drawing and images.
I plotted Striping Sheets 6 using DWG To PDF.pc3 instead of BlueBeam, and it seems to work OK. Try it.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 20
ChicagoLooper
Hi @jacksontdW23TR
You are connecting to WMS and using the imagery as a basemap and you are also rotating your views.
Unfortunately, AutoCAD is struggling to not only stream all that data but to rotate it too.
Your uploaded mages: (1) THis is shown before I plot to pdf. and (2) this is shown after I attempt to plot to pdf are not consistent. You want your BEFORE and AFTER to look the same, correct?
If that's correct, then try this:
  1. Zoom in to your area so your viewframes look like this. Make sure you 'capture both viewframes. See image-1.
  2. Right-click the WMS layer in the Map Task Pane=>RESAMPLE RASTER. See image-2.
  3. Zoom out to gain a wider view of your site. See image-3.
  4. Go to your layout tab=>Plot to PDF. See image-4.
Since the data you're bringing in has been resampled (reduced), AutoCAD is no longer overtaxed and can now adequately perform your plot.
Image-1Image-1
Image-2Image-2
Image-3Image-3
Image-4Image-4
When you Resample Raster, you are capturing the WMS portion that's displayed on your screen. Other parts of the WMS raster that are off-screen are not loaded into modelspace and that diminishes the heavy lifting AutoCAD must perform. To return to the 'original view' of imagery, zoom out, way, way out, then execute Resample raster again.
Attachment: PDF version
Chicagolooper
Message 9 of 20
jacksontdW23TR
Thank you so much for these detailed instructions. But, how do I capture an area? For some odd reason, my online map is disabled and the capture area as well.
Message 10 of 20
ChicagoLooper
Zoom in tight using your mouse wheel so the area displayed on your monitor is 'just right' not too wide and not too small (you want it wide enough to fill up the viewport but not so small parts of the VP has empty space).
Next, right-click the WMS layer in the Map Task Pane=>Resample Raster=>zoom out to view the 'captured area'
<<To open the Map Task Pane=> enter MAPWSPACE on the command line=>Then, while still on command line Select ON=>Enter=>Go to Map Task Pane and right click the WMS layer=>Resample Raster.>>
You may also experience a lag in the 'streamed' imagery. Be patient for the WMS server to respond (might be 5 to 30 seconds). Look closely at the bottom of your monitor, you may see a blue progress bar when the resampling is occurring.
Chicagolooper
Message 11 of 20
jacksontdW23TR
I am zooming closely in model space, correct? If so, I've done that and the instructions you have provided but I am getting the same result. I believe I am doing something wrong. Is image 4 the preview from the plot?
Message 12 of 20
ChicagoLooper
Image-4 is the plot. It's the same as the downloadable attachment at bottom of post #8.
  1. Enter MAPCONNECT on command line and the Data Connect Palette will open.                                                           .201.JPG
Chicagolooper
Message 13 of 20
jacksontdW23TR
 After resampling raster, I can a see a smaller clip for the two viewframes. Then, i went to a layout, striping sheets 6, went to plot manager and selected dwg to pdf ansi full bleed 11X17, hit layout, and preview. Then, this preview is shown.
Message 14 of 20
jacksontdW23TR
The linework doesn't show on the layout. The drawing has the linework behind the aerial image. You will have to send the aerial image behind the linework.
Message 15 of 20
ChicagoLooper
In the Map Task Pane, drag the WMS layer down so it's below Map Base.
You might need REGENALL (REA).
Chicagolooper
Message 16 of 20
jacksontdW23TR
unfortunately, it is showing up the same once I drag the wms layer down.
Message 17 of 20
jacksontdW23TR
unfortunately, it is showing up the same once I drag the wms layer down @ChicagoLooper
Message 18 of 20
ChicagoLooper
Select all linework=>right click=>Draw order=>Bring to Front
Chicagolooper
Message 19 of 20
jacksontdW23TR
I've done all the steps you told me to do. I still haven't gotten it to plot right. But, thanks for all your help! @ChicagoLooper
Message 20 of 20
jacksontdW23TR
can you send me the dwg file you were working on? @ChicagoLooper
