Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
How to generate table with alignment delta angle
eshabani9GA5S
eshabani9GA5S
At my current workplace. We typically use alignments to represent our pipelines. In the sections with the horizontal bends, there is a label style that will generate the delta angle of the two incoming lines.
However, I am looking for some sort of alignment report or table that will generate a table with the delta angle between my alignment lines segments. I've tried clicking through the alignment reports in the toolbox and have not had any luck.
See attached images to see what I'm referring to. The civil3d Alignment PI report will give me the direction of the line but not the delta angle. None of the curve reports or tables seem to be functional for me, not sure if this is because my alignment does not contain any curves.
hosneyalaa
@eshabani9GA5S
Hi
Can you attached example drawing
