Lineweight in Layout Viewport
AllenJessup
Mentor Mentor
AllenJessup
Yesterday I was trying to change the Lineweight of Contour lines in a Viewport. I tried changing it Bylayer and by changing it in the Style. No luck. Tried Audit and Recover. Nothing.
This morning I was going to post about it and started to go through changing in in the Style to get a couple of screenshots. It worked fine. No issues.
About 15 minutes later I noticed I only had the revised EP on a work layer for grading. So I extracted 2D polylines from the 3D polylines and placed them on a separate layer. Now I can't get those Lineweights to change. So a couple of screenshots of that.
Changed the VP Lineweight to something outragious to be sure it would be obvious.
Allen Jessup
CAD Manager - Designer
MMcCall402
Is the global width truly 0.00 or some smaller value that's rounding to 0.00
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
AllenJessup
I think you touched on the problem. The polylines were individually set to a Lineweight of 0.000... I believe this happened during the 2D extraction, using Sincpac, because the Lineweight in the Properties Palette (not selection) was set to zero not Bylayer. Don't know why.
I set the polylines in Modelspace to a Lineweight of Bylayer and they now work as expected. I don't think this was an issue with the Contour Lineweight because I never saw a Lineweight of zero.
BTW: The global width was and remains zero out to eight decimal places
Allen Jessup
MMcCall402
Ahh.  I've seen that sometimes with converted Microstation files.  Glad you found the issue and its resolved.
Mark Mccall
CAD Mangler
doni49
As to the contours issue:  I've had issues changing properties of a contour layer only to find out that the layer the SURFACE itself was on had a weird setting.  It's been a while since I dealt with that type of issue but hopefully it could help track down the issue.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
AllenJessup
I don't know what it was. Fixed itself overnight. So I can't track down anything.
Thanks.
Allen Jessup
AllenJessup
A little more research. Changing the Lineweight in the Properties Palette (with no selection) changes the CELWEIGHT. SysVar. So any entities created will have that Lineweight set to them individually.
Allen Jessup
