linetype3dplineon does not retain its setting when drawing is reopened
Message 1 of 9
When I use LINETYPE3DPLINEON it works fine until the drawing is closed. However, the setting is not saved between drawing sessions. Is there a cure for this condition? Thank you in advance.
Replies (8)
Message 2 of 9
tcorey
I've never heard of that variable (or is it a command?). Can you explain?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
Here is a link to a post on this forum about it. I could not find an answer to my question on the forum or online.
https://forums.autodesk.com/t5/civil-3d-forum/3d-polyline-linetypes-enabled/m-p/6540028
Message 4 of 9
tcorey
Now that I see what that is, add this to your acaddoc.lsp file:
(vl-load-com)
(vl-cmdf "LINETYPE3DPLINEON")
Every drawing you open will automatically have this value set.
Tim Corey
Redding, CA
Message 5 of 9
Thanks, just had not used my acaddoc.lisp for this version of C3D-always too busy to update it 🙂
Message 6 of 9
@tcorey  Where do I locate the acaddoc.lsp file?
Message 7 of 9
tcorey
If you're not already using acaddoc.lsp, find acad2020doc.lsp in C:\Program Files\Autodesk\AutoCAD 2020\Support\en-us.
Open with your text editor and saveas acaddoc.lsp. Place in C:\Users\yourusername\AppData\Roaming\Autodesk\C3D 2020\enu\Support.
Tim Corey
Redding, CA
Message 8 of 9
wfberry
Tim:
I was thinking that the .. 2020doc... worked the same as the acaddoc.lsp.
Bill
Message 9 of 9
AllenJessup
If you don't have an acaddoc.lsp file. Create it with notepad. I'd leave the acadYEARdoc.lsp alone.
Instruction on the usage of AutoCAD's acaddoc.lsp
Allen Jessup
CAD Manager - Designer
