Civil 3D Forum
LINE TYPES VIEWPORT SCALE CHANGES
4 REPLIES 4
luisL9R3L
431 Views, 4 Replies
Good morning, I have an issue with my line type scales, does not show how i want them
however i have set the PSLT and LTS at 1 and changes how i want it, but when ever I closed
the drawing and open again It does the same thing changes the scale. does anyone know what
it could be the issue so the line type stayed lock.
Labels (1)
4 REPLIES 4
MMcCall402
in reply to: luisL9R3L
These variables get saved with the drawing file and should stay as they were when last saved  .... unless your manager has your workstations set up the set these variables upon open a file.  Check with your CAD manager or IT manager if this is the case.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Whenever starting a drawing, I typically set the msltscale, psltscale, and ltscale variables to 1. While setting up your layout, make sure that your view port scale matches your annotation scale in model space.
I hope this helps.
If MSLTSCALE, PSLTSCALE, and LTSCALE are all set to 1, and your viewport annotation scale matches that of modelspace, everything should look the same between viewports and modelspace.  The linetype scales should not change on their own, unless some sort of customization is running.  Are you using anything like Reference Templates, or custom lisp/.net routines?  Linetype scale is not something that is associated by layer, it could be assigned by object, but would not change on its own.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
tcorey
There is also a variable, MSLTSCALE, which you should set.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
