Line & Curve Labels Not Showing
Usually these work alright, but I have a dwg with parcel object in it and it seems to only work for the parcel objects but not the normal lines and curves. Is there a setting that is not correct that it would only label parcel object but not normal lines?
Nvm, turned out the layer used for General Segment Label under Object Layers was shut off. Weird that it worked for Parcels but not for regular lines. I guess it sorts the layer depending on what type of object you attach the label to...
rl_jackson
Are you trying to label the line and curve with a Parcel Line and Curve label, they are distinct to one another, make sure your set to Line and Curve.
Rick Jackson
Survey CAD Technician VI
No, it was a general segment label that was labeling both regular lines and parcel segments.
