Usually these work alright, but I have a dwg with parcel object in it and it seems to only work for the parcel objects but not the normal lines and curves. Is there a setting that is not correct that it would only label parcel object but not normal lines?
Solved by rl_jackson. Go to Solution.
Nvm, turned out the layer used for General Segment Label under Object Layers was shut off. Weird that it worked for Parcels but not for regular lines. I guess it sorts the layer depending on what type of object you attach the label to...
Are you trying to label the line and curve with a Parcel Line and Curve label, they are distinct to one another, make sure your set to Line and Curve.
Rick Jackson
Survey CAD Technician VI
No, it was a general segment label that was labeling both regular lines and parcel segments.
