Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
labeling projected objects in cross section view
I have a surface, 2 different sets of featurelines (ROW and Edge of Pavement (EOP) lines which I created feature lines from) and I have cross sections every 5' along my baseline alignment. My problem when I project using "project objects to multiple views", and my ROW & EOP get projected to the cross sections, is that they display with their feature line style.
I want to label them specificly with 2 different styles. I don't know how to.
Could anyone help please? This is urgent..
Thank you
p.s. I can do each section view one by one but that would take forever..
tcorey
This will work if you place the various feature lines on different layers based on their styles, then freeze the layers that are not to have a particular label style before you run the projection routine. If you have two different label styles, it will take two iterations of freezing, running the routine, thawing, freezing, running the routine. More label styles will make this more cumbersome, but it's better than doing them one at a time.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Is there a better way of going about this yet? Seems like it would be so much easier if Autodesk just added a Projects tab to the multiple section views properties dialog window...
