Label formulas in Profile View for Network Structure - Is the Y exageration available ?
cyberflow
Advisor Advisor
Message 1 of 12
cyberflow
Hi all,
Trying to adjust the label to be at the bottom of the structure with formulas :
Is there a tag available for the exageration in the profile view so i can adjust the values in the delta Y so it gets scaled up and apply the exageration ?
I can't change the anchor point because we've got several set of labels that need to be inserted at the top already (For the buble identifying the structure) and then the bottom for the Inverts.
(French printscreen)
(English printscreen)
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Accepted solutions (4)
Replies (11)
Message 2 of 12
Ragdern
Sorry mobile formatting.
-((({structure height}/2)/{drawing scale conversion})*vertical exaggeration -from view style-)
that should get the tag to the bottom from a middle insertion.
Message 3 of 12
cyberflow
Hi @Ragdern !
I think "vertical exaggeration -from view style" doesnt exist i dont see it in the window panel suggested inputs
Frank Freitas
LinkedIn
Message 4 of 12
Ragdern
Sorry I should have been more clear. It will come from your profile view style. The graph tab and the value is the vertical exaggeration. I don’t believe there is a way to have the structure label read that. Most firms use a fixed exaggeration value across profiles so didn’t want to give a constant without knowing your setup.
for example mine is 8
Message 5 of 12
cyberflow
Gotcha
Yeah i noticed that dividing my calculated value with the Y exaggeration value makes my label position correct.
I dont want to create a formulas and styles as per each exagerration gona be a lot crowded
Frank Freitas
LinkedIn
Message 6 of 12
cyberflow
So after browsing havent found it possible so i put in a suggestion :
https://forums.autodesk.com/t5/civil-3d-ideas/add-quot-profile-view-exagerration-quot-and-quot-secti...
Vote for this if you find it usefull !
Frank Freitas
LinkedIn
Message 7 of 12
ChrisRS
I am not sure what you are trying to do.
Can you provide a better sketch?
Christopher Stevens
Message 8 of 12
cyberflow
Hey hi @ChrisRS
I'm trying to have those lists of inverts per structure under the structure when i insert them
The thing is that i've got already another label that is a buble that gets inserted at the top
So i cant really change the insertion in the template it's either i chosing top or bottom
Not sure if this helps .... tell me if i'm not that clear ill try to put in a printscreen
Frank Freitas
LinkedIn
Message 9 of 12
cyberflow
Now here i did dragged the lower label but i'd like it to be placed by itself underneath the structure
That's what i'm trying to do
Frank Freitas
LinkedIn
Message 10 of 12
cwr001
Hey cyberflow,
as you've found out yourself: the vertical exaggeration is not available in the expressions as it is a profile-view property that doesn't really have anything to do with the structures/pipes per se
(I'm with you that there should be a way to have the vertical exaggeration be recognized - it would be so much better!).
What I ended up doing in my template is to create an expression that reflects the vertical exaggeration for each "common" exaggeration that can later be referenced.
E.g. for 10 times vertical exaggeration:
{Zeichnungsmaßstab-Konvertierung}/10
This is painful because you have to create styles for every exaggeration that you want to have.
I've limited it to the most common ones (1, 2, 10) and have three copies of each style now.
Stupid, but it works.
Message 11 of 12
cyberflow
Hi @cwr001
That was my logic too but we'd have to crowd a lot of our styles like that
And we're in the process of simplifying everything, so it's a no go for us.
Frank Freitas
LinkedIn
Message 12 of 12
cyberflow
Well well !
I've found a way to put the label at the bottom and top !
In the template parameters i can specify to add "below"
And then i use the "Structure Dimension" in the anchor point inside the label
And tadam everything anchors correctly !
Inspired by this article : (Thx to the author !)
https://resources.imaginit.com/how-tos/civil-3d-making-the-most-of-pipe-setting
Frank Freitas
LinkedIn
