When annotating a line using the add label tool, then creating a table the text size shrinks by about half with the new numbers label. in the screenshot the bearing/distance label is the size shown before creating a table, after the "L1" label shrinks by about half the size. Does anyone know what would cause this and how to fix it?
Solved by user181. Go to Solution.
Edit the label style and go to the Layout tab and under Component name select Table Tag and then make sure the height of that is the same as your bearing, distance, etc. or whatever height you want it.
THE LABELS TYPICALLY CHANGE SIZE BASED ON THE SCALE I HAVE IT SET TO, IF THERE A WAY TO MAKE IT DYNAMIC BASED ON THAT. ( I KNOW THERE IS A WAY BASED ON WOKRING ON A TEMPLATE AT A PREVIOUS EMPLOYER IM JUST NOT SURE HOW)
The size of text in the label style will change when you change the drawing annotative scale but the Table Tag size may be assigned a different height than the bearing and distance label in the style. This would be why if you convert a label to a table tag it may change size.
