keyplan viewport in a plan and profile template civil 3d
1q2w3e4rr
1q2w3e4rr
hi
i want to have a keyplan in my plan and profile sheet template like the picture attached.
Joao-Rafael
Hi @1q2w3e4rr
Check this vídeo
Key Plan in CAD Layout Software - YouTube
At.t
João Rafael A. Dias
[pt] Esse post foi de ajuda para você? Mostre seu Apoio dando uma curtida! Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução '
[en] Did this post help you? Show your support by liking it! Did your question receive an answer that solved your doubts? Then click on the "Accept Solution" button.
[es] ¿Te ayudó esta publicación? Demuestra tu apoyo dándole un me gust. ¿Tu pregunta recibió una respuesta que resolvió tus dudas? Entonces haz clic en el botón "Aceptar solución"
Siga-me // Folow me LinkedIN
1q2w3e4rr
thank you for the answer 🙂
but it need an other software. do you know another way to do that?
Joe-Bouza
Setup your template with the hatch per frame on separate layers set frozen default.
after plan sheets are created use VPLAYER to taw per vport
Joe Bouza
1q2w3e4rr
thank you for your reply
do you know any step by step tutorial to do that?
Joe-Bouza
No. it is acad core command usage
You can freeze and thaw layers independently of view ports
say you have six (6) frames; make 6 layers for the hatch. somethin _keyplan hatch01...._keyplan hatch(n)
create a layer filer for ease of navigating
go to layout make key plan vp active open layer filter scroll to the right until you see the vpfreeze column and select all but the current key plan and choose freeze in that vport
Joe Bouza
