Civil 3D 2014 isn't reading my commands fast enough. It's not like I'm some super star typist but when I type "PL" then enter in C3D2012 I'm asked to specify start point but in C3D2014, typing at the same speed and same command, C3D wants to give me a high five or just wants me to PAN. Another example is the Extend command. I type "EX" then enter and C3D2014 assumes the Erase command. Is there a way to fix this? It's extremely annoying, especially when I'm in a hurry to get a project out of the door.
Thanks in advance.
Solved by ToddRogers-WPM. Go to Solution.
Turn off Autocomplete. Right click on the command line and expand input settings, then uncheck Autocomplete.
Set AUTOCOMPLETEMODE = 0. That will completely disable autocomplete.
Don Ireland
Engineering Design Technician
Andrew / Don - I appreciate your quick responses. However, my Autocorrect has been disabled.
Don Ireland
How I fixed mine is to go into the Input Settings (click on the little wrench on the command line) and set my milliseconds to 800. It's weird because at first I set it to a lower number and it was worse. I think the default is 300.
Todd - Thank you, sir. So, far this appears to have been the fix.
