Junction problem
Junction problem
alvaro.a
Junction problem
alvaro.a
Hi there,
I have this problem with the junction I'm creating. It looks like the contours are not smooth as it should be. Any ideas about how to fix this? Thanks.
neilyj666
As a starter make sure you are targeting the correct objects and building the surface from the correct links/features
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
alvaro.a
Thanks for your quick response. That was the issue, I've had the turn radius linked with polylines instead of alignments and the levels wasn't matching right. Now it's fixed. Thanks!
neilyj666
Great - glad it is fixed
