Junction and corridor surface dont align
daniel_martinF8PPE
daniel_martinF8PPE
So essentially, I have created corridors and tied them in in profile space and then used the intersection tool to create junctions. I have then added the junction corridor to the primary road. Once i then refresh the surface it does not line up with the corridor of the secondary road. The contours are only out by 10mm but is there a way to get them to align.
See image below;
It is the roads from the north and south that do not quite align.
Thanks in advance
Daniel
ecfernandez
Hi @daniel_martinF8PPE, alignments and layout profiles are set to build the corridor once you create the intersection. So, you can look for them and make the adjustments required to get the elevations on the mentioned road to align as accurately as needed. Furthermore, main roads' layout profiles might be adjusted when the intersection is created to accomplish modest conditions for the intersection. Therefore, if the changes that C3D makes automatically are not precise, we can always adjust what we need to increase precision.
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
