- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I carry out topographic surveys quite regularly using the classical method, GNSS and/or total station, for calculating volumes.
To prevent me from making mistakes when drawing. I collect break lines points with different codes, then in Civil 3D I use the transparent command 'PN associated with 3DPOLY to join the points in a certain range.
I wanted to know if there is a transparent command or a LISP in which the user just needed to indicate the raw description and it would automatically join the points with the same description, from lowest to the heights point number?
Thank you in advance for your help.
