Hello ,
I can't seem to find the tool to join multiple alignements or profiles , can anyone advice me on how to create a complex alignement/profile ?
Thank you ,
Solved by Udo_Huebner. Go to Solution.
There is no built-in command for joining alignments, but several workarounds that work well.
If alignments contain only arcs and lines, simply eplode them and then add them with "convert lines and arcs" to the primary alignment.
Or export multiple alignments to LandXML and combine them in a text editor and reimport the combined Alignment. Or use a dynamo script to combine multiple alignments.
Here is one of the last threads you will find here if you search for "joint alignments" with a link to the mentioned dynamo script.
https://forums.autodesk.com/t5/civil-3d-forum/joining-2-different-alignments/m-p/1946513#M42133
If you were to consider third party add-ons, DotSoft's C3DTools will join any number of alignments while controlling the primary. Associated labels are reassigned to the combined alignment and updated.
