- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, was wondering if anyone has had this issue before and knows any way to resolve it.
I’ve got a ground model which is a car park surface. Plus some additional surfaces, roads, footprints of building and related hardstanding etc.
The issue I’m having is when trying to add a grading to any of the perimeter feature lines which define the surfaces. This issue persists both when tying grading back to the existing surface or doing a grading to distance not tied to a surface
The grading creation seems to work, I follow all the steps and technically it’s created it (no errors) but for some reason no grading at all is visible. It’s like the dwg has an issue with generating any gradings.
I data shortcutted the surfaces into a new drawing and drew feature lines along the edgesm applying levels and done the gradings in the second drawing no issues at all. I can then data shortcut the grading surfaces back in. So I’ve got a workaround, but can’t figure out why I need to do this in the first place. Any ideas?
I should note there is gradings in the original model from a while back, it’s just any new gradings it won’t let me do. Perhaps a corrupt file?
Any help would be appreciated. Thanks.
