Hello, I am super new to Civ3D. I am having issues with the way autocad combines two surfaces. I have tried slicing instead of using paste surface, but it seems you cannot slice a surface with a surface?
If I select the two surfaces and view them in object viewer, I can see exactly where I need it to "trim" the surface. If it would let me ID an point of intersection of the two surfaces, I could just build a new one myself, but it will not. Using paste surface (I have tried reversing the order of selection as well) does not give me the surface I am looking for. I need it to combine where they both intersect and trim the rest.
Any advice on how to get this to work? I attached the DWG and a word file with pic for reference
Solved by ChrisRS. Go to Solution.
Solved by andrewpuller3811. Go to Solution.
Solved by MichaelH13. Go to Solution.
Christopher Stevens
