Issue with quick profile
mwaPT95E
mwaPT95E
I have a 3D polyline (stream thalweg) running along a surface (topo-bathymetry). When I plot a quick profile of the 3d line, I see an expected profile of the thalweg over the stream channel bottom. However, the profile graph also includes a second line, referred to as the "3DEntity Profile". This entity profile appears to show a 'hole' in the surface, where the elevation drops from 1459' to 0', before jumping back up to 1460'. It looks like a giant wedge in the middle of the profile line.
My confusion stems from the fact that the surface profile line does not have a 'hole' in it, nor does the surface itself. I have doubled checked to ensure the surface topo is good and that the thalweg polyline nodes are snapped to my survey points.  In the image below, you can see the two lines are nearly identical except for this weird 'hole'.
What is going on here? Am I over thinking something, or is there an error in my surface?
Thanks!
Matheus-Lima
Hi @mwaPT95E!
The surface profile is created following the polyline in PLANE and Civil 3D gets the elevation from each point from a surface. So if your surface is ok (apparently is) there will be no problem here.
On the other hand, the 3D entity profile is created following the polyline in PLANE and Civil 3D gets the elevation from the polyline vertices. If you click on the 3D polyline and see it in the object viewer, doesn't it have a hole in it?
Cheers,
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
jmayo-EE
I would first open the surface, get into a 3d view, displaying the TIN triangles and see if the surface is running to elevation zero. If so I would correct the objects forcing the TIN to elev 0.
If that step did not show anything at elev 0 I would then temporarily turn off or remove any surface boundaries to again see if the surface went down to elev 0. The profile may be ignoring a TIN Hide Boundary.
John
John Mayo
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
