Civil 3D Forum
Issue with multiple section view
5 REPLIES 5
f_paccapelo
387 Views, 5 Replies
Hi everyone.
When I create a multiple section view in Civil 3D 2021 I often encounter this problem:
while setting the layout  of the group, the single section get overlap each other. From this moment on there's no way to reorganize the section board. I tried to change any kind of section view settings, annotation scale, and also to recreate a new multiple section view from the beginnig...but with no results.
Has this happened to anyone else? How could i solve the problem?
In the pictures an example of the issue
Thanks for your help!
5 REPLIES 5
M_Obradovic
in reply to: f_paccapelo
Can you share the drawing?
f_paccapelo
in reply to: M_Obradovic
Hi M here's the link for the file download
https://www.dropbox.com/t/OyWLWN3m6U25l7d5
Thank you for helping me
M_Obradovic
Hi f.paccapelo
Sorry for latte answer, I took a look at your drawing and I have a few observations. It may be the case in your drawing that the alignment does not exist in the drawing, but it does exist in the corridor. Please see attached photo. As far as overlap section view I think issue coming from Group plot style. You have to set template for layout before you create multiple section views.
f_paccapelo
Hi @M_Obradovic
sorry for my late answer, i'll try as soon as possible your suggestion and let you know if i can solve it.
Thank you very much!
f_paccapelo
Problem solved!
Thank you @M_Obradovic, it works by setting the template, as you suggest!
Rail Community
