@rebeccaU9SLP wrote
<<The contour file is also supposed to be in WI83-CF. >>
Unfortunately, the coordinate system is not what you think it is.
A 'Best Practice' is to verify the Native Coordinate System of the shapefile. This is easily done by opening the shapefile's projection file (prj) using NotePad. The prj file is responsible for positioning the shapefile in modelspace. As long as you've assigned a coordinate system that's appropriate to your site, the shapefile will geolocate accurately. You don't need to edit or manipulate the prj, you just need to read it. Keep all the components of the shapefile (shp, shx, dbf and prj) in the same folder. You may even leave the prj open on your desktop while you perfrom MapImport. See image-1.
Image-1
Perform the MapImport command. The command requires some active input from you, the user. Be careful when viewing the Input Coordinate System column, it's the native coordinate system of the shapefile. There are 3 possible displays you may see: (a) the CS is displayed correctly, (b) a CS is displayed but AutoCAD is NOT displaying the correct one, or (c) AutoCAD is displaying <None> because the prj is not understood or the shapefile doesn't have a prj to begin with. Situation (a) is good. Situations (b) and (c) are not good and require you to manually input the correct CS that you viewed earlier using NotePad . Refer to image-2.
Image-2
After performing MapImport, you can turn on Bing Maps and see how your imported shapefile compares to Bing's imagery. See image-3.
Image-3
Chicagolooper
