Isolate Objects
Isolate Objects
CLG1972
Isolate Objects
CLG1972
There is probably an easy answer to this, however I cannot find the command to bring back all the drawing after isolating a feature line.
I used the 'isolate objects' command in the feature line tab, however there does not seem to an 'objects unisolate' command as in the layers (which I tried) to get the remainder of the drawing back. All the layers are on but only the feature line is visible.
AllenJessup
Quick guess. LAYERP Command
Also: AECUNISOLATEOBJECTS
Didn't quit get the icon in that shot.
Allen Jessup
CAD Manager - Designer
troma
You could also look for the little red light bulb in the bottom right corner of your screen.
I set up a shortcut for this one. In my pgp I set the command as AECUNISOLATEOBJECTS, but when I run it, it calls the command _.UNISOLATEOBJECTS
Mark Green
Working on Civil 3D in Canada
troma
Did you edit your post Allen?
I didn't see any pictures at first.
Mine looks quite different in 2013 (it's a light bulb icon).
Mark Green
AllenJessup
Yes. I've been throwing a few things in as I think of them. And yes the Icon has changed in recent versions. Maybe 2014, definitely 2015 and up.
Allen Jessup
