I created a bunch of pipe networks for existing sanitary and storm structures. As I started adding those networks to my profiles, I realized all the structures had a default sump depth of 2'. (Who came up with that?) Not knowing any better (first time doing pipes in C3D - although I've been trying to learn C3D for two years now), I changed the sanitary/storm structure rules to 0 sump depth and removed the rule for pipe drop, then selected all the structures for a given network and clicked Apply Rules, which made me re-select each structure starting from the upstream structure on down. I did this for a number of networks before realizing C3D was also changing my pipe inverts. See attached pics for one result.
Any idea what is going on?
[Rant to follow; fellow end-users please skip: This is beyond frustrating. It seems Civil 3D is designed to accept changes without confirming all the ripple effects someone at Autodesk thought would make sense to apply to my plans, or this is just bad programming, or a bug in the software, or just too complicated for anyone without a PhD in Autodesk groupthink to figure out?]
