Hey,
I've got to edit the descriptions of many pipes in my pipe network. Further down the line, these descriptions should propagate into other consumer drawings that reference this pipe network. These descriptions would form a part of plan and crossing label styles and they have to come from the source drawing.
Since I have to edit many pipes, it seems clumsy to have to MANUALLY enter the internal diameter of each pipe into its description field (I know the I.D. field can be extracted in a consumer drawing my making a label style that does so). I was simply wondering if it's possible to put in a field in the description of the pipe to extract the internal diameter of said pipe, much like how it would be done in a label style.
I have tried the following (to no avail):
Any ideas?
Solved by MMcCall402. Go to Solution.
the description field is propagated directly from the part list. These description are from the defaults of the catalog. The part list can be modified to have pipe descriptions as desired. The diameter of the pipe can be reached by its own parameter for label styles. In other words the catalog is wasting space.
to your current challenge; in the source drawing for the network you can make global changes to the descriptions.
in the Panorama sort your pipe and highlight the ones you want to change the shift and ctrl key will help. once selected right click the description heading of the panorama and type the description you want. This works for renumbering too
these edits will propagate to your host drawings.
Joe Bouza
As Joe said you can have the pipes derive their descriptions from the parts list name for each pipe. Below is where the setting is to make it use the description from the parts list rather than the description derived from the part definition formula. (partsizename)
Now, rather than editing the pipes one by one you can view them in the panorama in toolspace, sort it by pipe size, select all pipes of the same size, right click on the column heading for Description and choose Edit. This will then edit the description for all the selected pipes at one time.
I believe the description field is static so you can't add in your own code. Like stated above, you can group rename at the end or you can use Dynamo to set the names for you. Attached is a script I just wrote that can take the inner diameter and set that as the object description for all pipe networks in a .dwg. Hope this helps!
is there also a way, that the description in the pipes is not filled with any properties from the component list?
We use the description for numbering the inletts in a structure. If in a structur going two pipes the first has the description 1 and the other the description 2.
Currently we must remove the description in each pipe to get correct labels.
See result of the labeling in the attached file.
Thaks
Gerald
If you are trying to just clear our the default pipe descriptions, you can use @MMcCall402 method of using panorama to delete the auto generated descriptions. The default behavior is using size name as the description, but you can disable this in pipe network feature settings. Hope this helps.
