Civil 3D Forum
Is it possible to recover an unnamed, unsaved drawing?
21 REPLIES 21
Message 1 of 22
80764 Views, 21 Replies
This is more of a general AutoCAD question, but...
I had started a new drawing on our template and worked on it for an hour or so. I had not saved it or anything so it was simply titled "Drawing2.dwg." Well, during a simple text command AutoCAD decided to crash. It said it could try to recover the drawing, but when I looked around for it I couldn't find it anywhere.
I've had this happen before...is there ANYTHING that can be done or did I just lose all my work? Ugh...
21 REPLIES 21
Message 2 of 22
AllenJessup
Depends what your Autosave was set to. If it was turned on and set to less than an hour you should have a
 file in your Automatic Save File Location: asl.PNG
It should have an .SV$ extension. Make a copy of it and rename that file to a .DWG extension.
If you didn't have Autosave set there isn't anything you can do.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 22
in reply to: AllenJessup
I had a dwg crash also and found what looked like it was large enough to be my dwg file, it had an ac$ extension.  We attempted to change it to a dwg extension to restore it, but keep getting "drawing file is not valid" messages.  I've lost an entire day's work, is there anything or any way to convert this file to a usable dwg file?
Really appreciate any help, thanks.
Message 4 of 22
AllenJessup
Unfortunately the ac$ files cannot be used for recovery. Only the sv$ are useable.
Allen Jessup
Allen Jessup
Message 5 of 22
rkmcswain
That is because.ac$ files are temporary files of variable content and not .dwg files
http://usa.autodesk.com/getdoc/id=TS1062993
I know it doesn't help now, but were you unaware that you could "lose a whole day's work"?
Did you think that AutoCAD saved the current file for you like some other programs do?
Just wondering.
R.K. McSwain     | CADpanacea | on twitter
Message 6 of 22
in reply to: rkmcswain
The OP probably didn't realize that AutoCAD is so unstable that it crashes on a daily basis. I was also surprised of the program's instability when I first started using it. Most of us expect programs to just work, all the time, and only crash occasionally when we do things we're not supposed to, i.e. a browser only crashes when you open 100+ tabs, excel will only crash if you write a dumb macro, etc..
Message 7 of 22
dgorsman
Daily crashes are certainly *not* common.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 8 of 22
neilyj666
I certainly experience crashes at least once per day. ..
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 22
in reply to: neilyj666
I also deal with crashes at least once per day, not always due to CAD, but it is the most frequent culprit.If your CAD isn't crashing, you're not utilizing C3D's full potential, as illogical as that sounds.
Message 10 of 22
rkmcswain
...a browser only crashes when you open 100+ tabs, excel will only crash if you write a dumb macro, etc..
I suspect most browsers and Excel combined don't contain 1/10th of the code that vanilla AutoCAD does, not to mention the verticals. I live with a crash or two a day because the pros far outweigh the cons.
Message 11 of 22
I totall agree. But since we're not all programmers, and if you've only used much simplier applications previously, it's hard to comprehend the problems AutoCAD can have. I run into this on a day to day basis when I try to explain to my bosses that I'm having technical issues, and they look at me like, "What with that big calculator (computer) you use? Are you hitting the wrong button?" They cannot comprehend that there can be problems within software that is beyond user control. Many (most) people feel this way about software.
Anyway, I was just trying to defend the OP's point of view.
Message 12 of 22
AllenJessup
I use Civil 3D. I wouldn't say that it crashes daily. But it can do it often enough that I'm careful about saving. I also use Autosave.
A trick I use is that I create a folder for the Autosave files and deny the SYSTEM the rights to delete files from that folder. That way Civil 3D can't erase the files if it thinks it's closed correctly. It also provides me with a pretty good chronology of the project. The down side is that once a month I have to remember to erase the useless files and write the useful files to an external drive so the temp file location doesn't get choked.
Allen
Allen Jessup
Message 13 of 22
ccoles
Around here, we say that if Civil 3D doesn't crash at least once a day, your not using it correctly. I've been adamant about having me and the other CAD techs using autosave and just hitting the quick save button on a regular basis. And, teach them to save to some filename somewhere once you start working a brand new file. I don't know if autosave can kick in unless you have it saved with a filename to a directory. I can easily say that autosave has saved me worlds of hurt in the past. Like sometimes when you're so deep into a design, forget to save, and Civil 3D decides to crash just as you try to make a simple adjustment to a feature line or edit some text. Losing 10 to 15 minutes of work sure beats losing 2 hours of work.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Message 14 of 22
I didn't think AutoCAD was necessarily super unstable until recently. Did they do an update or change something? Because I've been working in Carlson 2014, and it's crashed more on me in the last 2 weeks than in the preceding several months. I've had it crash at least once daily, often more than once, in the past 2 weeks. And it's usually when you're doing something simple like trying to undo, or do a double-click edit on text, or even just switch layout tabs. Thank God for Autosave at least.
Message 15 of 22
andrewpuller3811
If you autosave is enabled, check in your temporary folder as suggested above.
If you did not save the file, the autosave files will have a names like
Drawing1_1_1_2129.bak
Drawing1_1_1_2129.sv$
Other than that, I think you are out of luck.
Best to have save a drawing before you do any work, even if it is in a temporary location, and you can move it later.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 16 of 22
You just saved my day Allen! Thank you!
Message 17 of 22
neilyj666
A method I've started to use is to type SAVE on the command line which will obviously save but will allow you to rename and will then continue in the original file.
Message 18 of 22
AllenJessup
Glad it helped someone. Welcome to the forum.
Allen
Allen Jessup
Message 19 of 22
bzvj
Thank you for the question, and thank you Allen....it works for me...soooo please it works....awesome..
cheers,
Message 20 of 22
cvlci_CAD
Allen Jessup
Not entirely true.  You are correct with the ac$ files but believe or not, you can sometimes use the .tmp files that are created.  Not sure if windows creates them between the time the autosave is started and the .sv$ is created but it happens.
Rail Community
