Is it possible to MERGE two different copies of a drawing?
ChristopherVolosy
ChristopherVolosy
We use a Cloud system and it doesn't alert us if someone else is working the in same drawing.
When we each save, there are then 2 copies of the same drawing with different items changed in each.
Is it possible to merge the copies of the same drawing to get both sets of changes?
AllenJessup
Not directly. But you could use the Compare command to bring changes from one drawing into another.
Allen Jessup
CAD Manager - Designer
Joe-Bouza
Not to be snarky but you need a better system.  For example Bently Projectwise (works with civil 3d) checks out  a drawing for editing and locks the copy in the cloud.
Joe Bouza
pkomatlapalli
Hello @ChristopherVolosy ,
Just checking in—did the responses shared by AllenJessup and Joe-Bouza  help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
Pavan Kumar | Community Manager
